Re: Flywheel bolts nicked
Martyn-----
I think the Ram 14" flywheel will be ok IF we're talking about a cast iron or steel standard weight flywheel. You can also use GM #3991469. It's about 240 bucks, GM list, though.
As far as pressure plate and friction disc are concerned, GM is not an option unless you seek out NOS. The GM pieces have been discontinued for quite awhile now. I think you'll find that a Sachs or LUK will be a very satisfactory replacement.
DEFINITELY have the flywheel and pressure plate assembly balanced before installation. It may be that little or no weight will need to be added or removed. But, you want to KNOW that BEFORE installation.
Martyn-----
