Greetings. I have the main shaft assy on the bench with the forward snap ring removed but the syncronizer spline will not slide forward off the shaft. It appears to be contacting the forward groove area where the snap ring rests. Is removal of the syncro and 4th gear toward the forward end of the shaft? Thanks, Dan
T-10 4th Gear Removal
Re: T-10 4th Gear Removal
Dan, Someone will correct me if I am wrong but I think the syncro will tap off with a block of wood, make sure you keep it square when tapping. The next gear (Third) will also remove from the front.
- Top
Occasionally a press is required, I use a samm one from Harbor freight and have never either broken anything nor found a trans that would not disassemble with that pursuasion.Bill Clupper #618- Top
