Hi All;
I'm into my second "rebuilt" T10 (since 2005), this second one a correct 1963 only unit. This one, like the first one leaks like crazy from the front of the main case where the counter shaft comes through.
On the one I just took out, I had put some cold weld over the shaft hole which reduced the leak, for a while. For this new "correct" unit, I want to fix it right particularly if I am going to take the whole *^%#$%& thing apart.... again!
What is the conventional wisdom to get this fixed so it won't leak??? Any recommendations for someone in/near NJ who can do this work??
Thanks!!!
Joel
Thanks!!!
Joel
