75 / 76 Shock Absorber Numbers - NCRS Discussion Boards
  • Alger R.
    • September 30, 1999
    • 279
    Does anyone have the correct Numbers and Label Codes for the Front & Rear Shocks for 1975. The NCRS Judging Manual does not show a number for Ft or Rr. The Assembly manual shows 4984667 (Ft) & 4984803 (Rr) I have a front set for a 76 dated Aug 75 with part number 4984667. This is inconsistant with the Judging Manual for 76. The label on this 76 set is C K which is also inconsistant with the Judging Manual- I am hoping that I can use these on my 75 but concerned with the C K label? I realize the date is after my build date (April 2) but may have to accept .
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
  • Alger R.
    • 279
    Re: 75 / 76 Shock Absorber Numbers
    Corrections to original post...The 75 Rear Shock part number in the assembly manual is 4984667. Also I have a set of front shocks - Can these be 76 Corvette?? ...Pliacell 4984577 235 75 Label C K
    AL
    75 Convertible
    L48 M20
