Hi Guys;
From time to time, without a pattern that I can readily pick up, my 1963/340 will diesel after I shut off the ignition. Happened last night coming back from "classic car nite" at our local diner (gets you a 20% discount off dinner!). I stopped for gas and she kept running... a few seconds, like 2 to 3. When I went to start her again after my fill up, she was a bit flooded, and once she did kick over, the idle was low... like 500 RPM...
I drove the car home and put her in the garage.. By this time the idle was back to normal (around 1000 RPM)... She shut off without a peep.
Stock distributor with the correct vacuum can (within Joe's 2" rule), stock timing, valve lash etc. Stock carb recently rebuilt...
Any ideas?
Thanks in advance,
Joel
Any ideas?
Thanks in advance,
Joel
