C1 and C2 Ballast Resistors - NCRS Discussion Boards
  • Christopher R.
    • March 31, 1975
    • 1599
    I wish to use the later version of the C1 and C2 ballast resistor in my car with a points type ignition system. The one rated at 1.8 ohms. They are still available. I bought 2 today. However, both of them measure 2.4 ohms at room temperature. Would a 2.4 ohm one work acceptably? Is the delta between 1.8 and 2.4 ohms something with which I need to be concerned?
    P.S. One of these resistors is made in the US! A BWD RU4. Floored me when I read the box and saw "MADE IN THE USA". When's the last time you saw that?
    Re: C1 and C2 Ballast Resistors
    Christopher -
    Shouldn't be an issue - the resistors I've been using for several years check at 2.1-2.3 ohms at room temp, and they work just fine.
    • Roy B.
      • February 1, 1975
      • 7044
      IF your looking for the real deal original first "design" this is what it should look like.
      • Mike M.
        • May 31, 1974
        • 8365
        roy's picture is correct for at least the 56 and 57's. note the lack of a notch in the porcelain on the sides beneath the screws. mike
        • Roy B.
          • February 1, 1975
          • 7044
          Thanks mike I knew 55 to 57 but wasnt sure about later C1's
          • John F.
            • March 23, 2008
            • 2395
            Which one is correct for a 62, 250hp-327? Notch or no notch?
            • Roy B.
              • February 1, 1975
              • 7044
              62 I'm not sure of but some here should know, I know 55 to 57 mostly
                My recollection, based on 'harvesting' ballast resistors, is the ceramic change (trough from the center to the screw terminals vs. trough all the way through to the outer ends) came along in roughly the '58 model year...
