I have 67 L36 with AC and PS. When I started to fit the water pump pulley, the pulley rubs against the top edge of water pump. I check the water pump casting and it is 3856284 which according to Corvette by Numbers book is correct. The water pump pulley casting is 3889372 which according to AIM is correct.
I bought repo stiffener/reinforcement plate from LI Corvette which look a little thin but assume it is correct. Also, checked that pulley was not bent which it seems ok. At his point, I'm run out of options other than the shaft or mounting plate is incorrect on the water pump which was rebuilt by someone before I got the car. Also I have not installed the belts to check to see how out of alignment they are if at all.
Any other ideas what I might check ?
