Now that I'm straight (no pun intended) on the distributor positon,,, what about the vacuum fitting position?
I have no A/C, and no power brakes. So my fitting only has one port in which a hose runs to the white filter.
What direction should this port face???
Right now it is pointing toward the passenger door, about 4 o'clock, and the hose goes around behind the distributor toward the vacuum tank.
Is this correct?
Or should it point right at the vaccum tank, 8 o'clock?
How long should the hose be before the filter?
Is this correct?
