67 wiring issues - NCRS Discussion Boards
67 wiring issues
  • Jeremy H.
    • January 1, 1999
    • 260
    67 wiring issues
    Just finishing a frame off om a 67 and have only one issue left. When you pull the headlight to either #1 or #2 position the left turn signal indicator is on steady. I checked the wires and it is correct. Everything else, so far works.
    Any thoughts?
    Jeremy Hedges
    #31711
  • Robert T.
    • May 31, 1993
    • 346
    Re: 67 wiring issues
    Sounds like a missing ground issue. You can get some pretty wierd sneak paths in the turn signal/ parking lights area if one is missing. I'd check to be sure your bulb sockets are indeed grounded on the turn signal/parking lights.
    bob
    • Rich P.
      • January 12, 2009
      • 1361
      Jeremy,
      I also have had 2 brand new repro 67 headlight switches on the last car I did that were bad and gave me similar problems. And I also had new front parking lamps that were not grounded correctly that did the same thing. I found that out by jumping a ground to the lamps.
