Discovered a new noise while taking the car for it's first spin the spring. Sounds like a u-joint. The drive shaft has zerks on both ends. I was able to grease the front one but was unable to service the rear. The half-shafts do not have zerks. Question is: since there are 6 u-joints how do I go about figuring out which one(s) is causing the problem? By visual inspection they look fine. Or do I have to tear into it and replace all of them? Or is there something else I'm overlooking?
It's a 66 small block with 4-speed.
Thanks for any advise!
Tim
Tim
