Need U-Joint advice - NCRS Discussion Boards
Need U-Joint advice
  • Tim L.
    • January 1, 2005
    • 141
    Re: Need U-Joint advice
    I don't know what LICS is selling, but what you want is Spicer joints with no grease zerks. Make sure the shop you use knows that replacing the outboard U-joints requires a spare flange or steel plate bolted to the existing flange to avoid bending it while replacing the joints, or you get to spend sixty bucks per side for new flanges. If they don't know that, go elsewhere.
    Thanks John for the tips. I have some Spicer joints located and will tackle this project this weekend. I hope it's the cause of my noise!!
    Tim
