Thought I would post a picture of the bushings I installed in my 3810 base plate. I used valve guide bushings and the diameter is .371-375. The drill had a pilot and reamed the hole to .405 then tap the bushings in for a nice fit. The shaft is very nice fitting, not tight but just right.
I had to install a new secondary shaft because it was wore but suprisingly the primary shaft is very good. I think from a previous rebuild someone may have damaged the secondary shaft and installed a used shaft. I drilled completely through the sides and installed the bushings through the entire length.
Also shown is my sanding table and 220 wet paper. This did a fantastic job showing the low spots on both sides of the base plate and was easy to do with the throttle shafts removed. Finally, I taped the two unused screw holes and will install screws from a doner in hopes of a good gasket seal. I don't think it's necessary but I did it anyway.
