I recently purchased a bbc engine, casting number 3855961. Reading Chevy v8 Engine Casting Numbers" It says this is a 396 or 427 block. The crank is a 3904815, which the book says can be either a 396 or 427. This engine has .030 over pistons in it, with a bore size of approx. 4.14, which I believe makes it a 402.
Did Chevrolet make a block that could be either size, depending on how it was bored? Are all 961 blocks identical, regardless of finish size? If so, can this block be bored to 427 specs?
It would seem odd to me that there are two blocks with the same casting numbers, but different interior specs.
