63 L84 distributor problem - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2155
    Four of the eight plug wires on my engine are getting no spark from the distributor. These are the four consectutive teminals on the rear of the distributor. Is this most likely a cap, rotor, or distributor problem?
    Thanks, Mike
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 63 L84 distributor problem
    Michael;
    Looks like you need to do some troubleshooting. You'll have to pull the cap to check it and the rotor, but most likely it would be the plug wires. You didn't say what system you have so I assume it still has points and condensor so you'll want to check them as well. No spark on 4 of 8 wires (where did you check?) is more likely the wires or, in severe cases, you could have electrical paths to ground. Look for red carbon tracks inside the cap.
    Stu Fox
    • Michael G.
      • November 12, 2008
      • 2155
      We checked all wires, they are good. We replaced the rotor with one I know works, then tested output from each terminal on the cap, using a good plug wire. No spark from those four terminals, still. The cap is a new repro, it may be defective.
      Mike
        • April 30, 1984
        • 158
        Are they one side of motor,(left side,right side),in fireing order, or just random.
        • Michael H.
          • January 29, 2008
          • 7477
          Mike
          If the point gap/dwell is off, a lot, it's possible that they're opening just enough on some of the cyl's to fire the coil, but not others. Almost all distributor main shafts/point cams run untrue enough to cause a dwell variation, enough to create this problem. It's actually a somewhat common issue.
          • Michael G.
            • November 12, 2008
            • 2155
            Thanks guys. I threw an old set of points in and the problem went away.
            • Michael H.
              • January 29, 2008
              • 7477
              Mikey gets a gold star for that one.
              • John D.
                • December 1, 1979
                • 5507
                Yeah that was really a hard one to figure out MH.
                Get rid of the foreign made Delco points as typically they sure won't let you rev much over 4 grand and that's giving them the benefit of the doubt. Hurry and stock up on some NAPA points while you can still get them. The good Perforated (P) points are history. Discontinued like everything else. JD
                • Larry M.
                  • January 1, 1992
                  • 2688
                  John and others:
                  ACCEL still manufacturers high performance points for the Delco distributors (and their own ACCEL version of such). These are excellent points and in my opinion equal to or better than the Delco D-112 high performance points. Price was still resonable last time I looked.
                  Part # 110128 for points alone and #8104 for points and condenser. These will rev to 6500-7000 RPM redline without issue.
                  Larry
                  • Stuart F.
                    • August 31, 1996
                    • 4676
                    Well, you guys win on that one. It's been many years since I worked with points and condensors, and it will be forever before I will again. I like my redline at will car.
                    Stu Fox
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      If it was so easy, how come YOU didn't answer the mans question? Oh, wait, I know. You had boo coo (did I spell that incorrectly, like you do?) work to do and didn't have time?
                      • Michael G.
                        • November 12, 2008
                        • 2155
                        Well, I'm glad I'm having problems that you guys have seen before. I'm desperately hoping not to find one that nobody's ever heard of...
                        Thanks, again,
                        Mike
