77' tachometer - NCRS Discussion Boards
77' tachometer
  • Michael B.
    • April 1, 1999
    • 178
    77' tachometer
    Does anyone know what the 2 chips are on the 77 tachometer pcb?
    One has numbers but I have never been able to find a reference. The other has no markings at all. The resistor is a no-brainer, it's burnt but the colours are visible.
    Michael B.
  • Ken A.
    • July 31, 1986
    • 929
    Re: 77' tachometer
    Yes, but both are N/A
    • Michael B.
      • April 1, 1999
      • 178
      Re: 77' tachometer
      Hi Ken,
      Are you able to supply the references. We have a couple surplus suppliers in the area.
      Thanks for the response though.
      Cheers.
      • Ken A.
        • July 31, 1986
        • 929
        Re: 77' tachometer
        You're better of buying a Gardner board that's precalibrated than pursuing long gone parts.
        • Tom R.
          • June 30, 1993
          • 4081
          Re: 77' tachometer
          If its an original board and you're referring to the black and white chip, its a fixed resistor used to calibrate the board. To be precise, its a 14 pin chip-type fixed resistor network called a Dual in-line Package (DIP). It's a DIP Ruthenium Oxide device. They were last used on 96 boards and are replaced with a variable resistor on replacement boards.
          As suggested, Gardner's boards are an excellent replacement choice. After doing some extensive research on the boards, I would recommend replacement rather than repair. Fresh components, precise calibration and copper paths that are thickened to absorb electrical malfunctions.
          Tom Russo
          78 SA NCRS 5 Star Bowtie
          78 Pace Car L82 M21
          00 MY/TR/Conv
          • Michael B.
            • April 1, 1999
            • 178
            Re: 77' tachometer
            Thanks Tom and Ken.
            OK, a Gardner board it is then - if someone can point me in the right direction. I think I've seen the name before but not sure where to find it.
            Greatly appreciate the technical response. It is an original board. A resistor pak makes sense.
            Michael B.
            • Michael B.
              • April 1, 1999
              • 178
              Re: 77' tachometer
              Looks like I've found his stuff sold by Corvette Central. Correct ??
              Cheers.
              • Tom R.
                • June 30, 1993
                • 4081
                Re: 77' tachometer
                Cheers.
                Not sure...I'm on the road but sounds about right
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                • Tom R.
                  • June 30, 1993
                  • 4081
                  Re: 77' tachometer
                  Looks like I've found his stuff sold by Corvette Central. Correct ?.
                  To contact John Gardner email at jtandjudyg@aol.com or 610-797-4048
                  Tom Russo
                  78 Pace Car L82 M21
                  00 MY/TR/Conv
