Tri Power 3x2 Center Bowl Vent- Usage? - NCRS Discussion Boards
  • Jamie F.
    • May 20, 2008
    • 337
    I have a late '69 L68 with carb dates of 992. My center carb has a float bowl vent on top.
    Many if not most 3x2 I see do not have this vent.
    Does anyone know the time frame of usage of this vent, or if it was only on certain applications?
    I looked in the archives and noticed that someone mentioned the -1 after the carb number indicated a vent, but no info on when or what it was used from, or on.
    Thanks!
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Tri Power 3x2 Center Bowl Vent- Usage?
    Jamie -- I know little about C3's, nor do I have any of the NCRS manuals, but I do have a late '69 oval tri-power setup, with the center carb [3940929 LIST-4055-1, dated 981] ie. about 3 weeks earlier than yours.
    I does have the center bowl vent (rubber flapper on a hinged arm connected to throttle linkage). Sorry I can't offer when this began.
    • Jamie F.
      • May 20, 2008
      • 337
      Thank Wayne. I believe most of '69 should have the vent valve. I think many of what I see are service replacements or had their float bowls replaced some time in the past?
      • Tom H.
        • May 31, 2003
        • 89
        I have a early 69 set up, and the center carb is dated 881. It does not have the vent.
