I plan to repair the leaking countershaft on my 66 roadster tonite. Plan to seal the leak by moving the trans back to access the countershaft case area. Can the trans be moved back without the need to drop the driveshaft? I figured that the shaft would slide back about 1 to 1 1/2 in or so on its splines without the need to drop the shaft.
Dave K.
Dave K.
