Re: 63 Steering Gear "Check-Lube" Survey
Stu;
If you look at the steering knuckles (as I recall.. I'm doing this from memory).. there are two places where the tie rods can connect.. one is standard steering the other is the "quick" option. You can swap it back and forth by moving the tie rod ends but I suspect it will require a realignment of the front end.
Others probably have more information...
Joel
Stu;
Joel
