C2 Play at the camber adjusting bolts - NCRS Discussion Boards
  • Hans R.
    • March 1, 1976
    • 91
    I'm assembling my rear suspension on my 1966 Coupe. When making sure I have all the parts, I see that the strut rod have a lot of play on the camber adjusting bolts. The strut rod bushings and caps are new but I've kept the original camber adjustment bolts. Will this play disappear when it is all mounted on the car and tightend to spec's (55-75 lbs)?
    Hans Ryden #868
    Hans Ryden #868
    Re: C2 Play at the camber adjusting bolts
    Hans Ryden #868
    Hans -
    It will if you have the correct special steel caps on both ends of the inboard bushings.
