Basic question: What are the correct finishes on the carb stud, nut, and washer? This is not specifically addressed in the TIMJG. No luck searching the archives either, but I did see a discussion suggesting that perhaps a separate nut and washer may have not been used for this year. Any further comments on this?
71 LT-1 carb stud
Re: 71 LT-1 carb stud
The nut is somewhat unusual in configuration. I lost your post yesterday afternoon when I went to the desktop to post the picture of the stud and nut on my 1970. I hope I can fnd yoru post tonight.Terry- Top
Robert,Basic question: What are the correct finishes on the carb stud, nut, and washer? This is not specifically addressed in the TIMJG. No luck searching the archives either, but I did see a discussion suggesting that perhaps a separate nut and washer may have not been used for this year. Any further comments on this?
I've attached a couple of carb. photos of my 71 LT-1 5 star car. Of the 4 nuts one has the throttle cable bracket under it and another has the fuel line bracket. The other 2 go directly to the carb. base. None of the 4 have lock washers. Nuts look to be plated with zinc or cad.- Top
Robert,
It's a little hard toi get an accurate measure but the nut is about 5/16" high.- Top
Thanks, Dave. It the nut is 5/16" thick, then from your pics it looks like the stud rises about 5/8" above the nut for the right rear with the fuel line bracket. So, I would guess the total stud height projecting above the top of the carb base to be approximately 1 inch.- Top
Robert,Thanks, Dave. It the nut is 5/16" thick, then from your pics it looks like the stud rises about 5/8" above the nut for the right rear with the fuel line bracket. So, I would guess the total stud height projecting above the top of the carb base to be approximately 1 inch.
That looks right. I don't think any judges will be measuring but if you have around 1" to 1 1/8" you should be fine.- Top
- Top
If I add in 1/2" for the carb base and 1/4" for the insulator/gasket, it looks like the total stud height above the intake manifold should be around 1 3/4".- Top
