I had a small leak.. a drop or two from the differential at the pinion seal.. I had the seal replaced, with a new seal.. Now the leak is a drip... and is much worse...
Looking for some advise... Is a speedy seal the way to go now.. or is there something else i should be doing?
Some information on the rear end in my 60...
The 3725899 center section was stamped BO618 which, I was told it's a Buffalo passenger car housing cast on June 3, 1964, and assembled on June 18, 1964. These casting were used on '57-'62 Corvettes and '55-64 passenger cars for non-Posi applications;
Thanks..
Joe
Thanks..
Joe
buy a double lip seal
