C2 speedometer cable replacement ? - NCRS Discussion Boards
  • Dale T.
    • February 1, 2004
    • 11
    Is there an easy (???) way to remove the speedometer cable at the transmission on my 64 4 speed? The previsous owner apparently had the wrong cable so I thought I would replace it with the correct one, only to find out that between the shift linkage and the transmisson mount brackets I can't get my fingers on the lock nut with enough pressure to twist it off. Am I missing something obvious?
  • Greg W.
    • August 31, 2005
    • 117
    Re: C2 speedometer cable replacement ?
    When you find out let me know, I have a 63 and can't get to mine either. I did ask the same question awhile back and someone suggested replacing the cable. I think the way I understood it was that if you disconnect it from the speedometer you can pull it out of the sleeve and the insert a new one. I guess that won't help you if the sleeve is the wrong color.
    I hope someone helps out on this.
    • Wayne M.
      • March 1, 1980
      • 6414
      Originally posted by Dale Tennant (41361)
      Is there an easy (???) way to remove the speedometer cable at the transmission on my 64 4 speed? ...... between the shift linkage and the transmisson mount brackets I can't get my fingers on the lock nut with enough pressure to twist it off. Am I missing something obvious?
      Can't offer you a certain solution but can you get a small 7/16" socket or wrench on the bolt that retains the 'thingy' (bullet ?) that holds the speedo driven gear in place, then grab the cable and pull / twist until it comes out, hopefully without dropping the plastic gear into the tail piece.
