RPO 684 Rear Springs - NCRS Discussion Boards
  • John N.
    • February 1, 1975
    • 451
    Re: RPO 684 Rear Springs
    Originally posted by Ken Havranek (46615)
    John,
    Can you tell me who Franz is??
    Also, where would you recommend I take the measurements from?? Should I only compare to the spring I have or should I go ahead and post the measurements here??
    On my single '58 spring, does the stamp seem correct (again, it would be great if there is another RPO car with springs dated around or after January '58 to compare to)?? It is facing a different way and the sequence is different (the "E" for Eaton Springs is in a different place than it is for all of your springs)?
    Thanks again,
    Ken
    Ken
    I sent a PM to Franz and I believe if he has the time he will answer your questions. You should measure the thickness of each individual spring leaf and compare. He may have you measure the individual lengths. I think the stamping on your 1/58 spring is okay but it would be best to compare it to a known spring(s).
    Regards
