The light comes on intermittantly, sometimes when parked and some times while driving and when it does, pushing the light switch will turn it off like it is supposed to.
I believe that there is a loose connection and I can not find the wiring on any electrical schematics.
I have checked and replaced the bulb.
Does anyone know how this is connected? I assume that it is connected to the ignition switch.
Is there anything in the panel that can be replaced?
Other ideas or suggestions??
). You will need to remove the little board to access the electromagnet.
