My key cylinder will not lock into the slot in the steering column. The spring that makes the cylinder tab go into the slot seems to be keeping some pressure on the tab. Any ideas?
1970 Steering Column - Key cylinder won't lock into column
Tags: None
- Top
Re: 1970 Steering Column - Key cylinder won't lock into column
Steve,
Not to belay the obvious, but you have tried pushing around the shifter to make sure it is in reverse and moving the steering wheel to get the lock in place? Sometimes it takes a try or two to get these old cars to remember.
Ken- Top
From my T&T Steering Column Disassembly & Repair Paper #1:
Reassembly - Ignition Lock Cylinder
There is a keyway in the housing. Align the key on the lock cylinder (not the ignition key but the raised section on the lock cylinder case) with the keyway in the housing and push the cylinder into the housing until it hits the sector. Now rotate the ignition key counterclockwise maintaining a light push on the lock cylinder, until the drive section of the cylinder mates with the sector. Push in until the locking wedge snaps into the housing and the lock cylinder is secure.
Hope that this helps,
Jim- Top
Thanks for your help. The case was slightly bent. I repaired the case, and the key tab locked. Thanks for you advise.- Top
