Sun Visor Droop - NCRS Discussion Boards
Sun Visor Droop
  • John C.
    • September 30, 2001
    • 130
    Sun Visor Droop
    Any ideas on how to keep the vison up? I have the set screws in place but this really does not work
    Re: Sun Visor Droop
    Typically, the fault flows from wear on the interference fit between the reinforcement plates in the visor and the hinge pins attached to the WS header they 'bite' against. If the wear is excessive, you're looking at replacing the hinge pins, visors or both. OR, devise a method of 'shimming' the interface to compensate for the wear factor...
