Haven't replaced spark plugs in years. Can you still get ACs? What are your recs for a basic 250hp motor? Nearest auto parts store is O'Riellys or Advanve. I will also be doing a compression check. Have owned the car for about a year and have never touched the plugs.
Correct spark plugs for 327-250hp
Re: Correct spark plugs for 327-250hp
If you want a non-resistor plug (like OE) equivalent to the discontinued AC 45, the Denso W14-U and NGK B4 are it for SBs with gasket seat plugs.
For all OE vintage engines - both SB and BB regardless of power rating - a heat range equivalent to AC "5" is best to avoid premature fouling, and they won't overheat in sustained high speed freeway cruising.
If you run race track hot lap events, install a plug equivalent to AC heat range "3" for SBs and "2" for BBs.
Duke- Top
I just put in a new set of R 45S from Advance and all is working fine.If you want a non-resistor plug (like OE) equivalent to the discontinued AC 45, the Denso W14-U and NGK B4 are it for SBs with gasket seat plugs.
Duke- Top
