What I thought was a fuel pump problem turned out to be a problem with my carb.
A little background info: The car had been running great without any issues until one morning when I tried to start it up. The motor would just spin over.
Whatever caused the non-start happened while the car was sitting in the garage.
Today, I got a chance to take a closer look at it and found that for some reason the accelerator pump lever was in a bind. I took the carb off and the bowls were full of gas so I knew the fuel pump was working. I fiddled with the lever and got it moving again so I put the carb back on and tried starting the car again. It cranked, but now has an off idle stumble. The carb nozzles drip fuel when pumping the accelerator lever. The car would start back up and idle continously while hot. The car would not start after I let the car sit for a few ours to cool down. The accelerator pump lever was once again in a bind.
What could be causing the accelerator pump lever to bind up?
