My early 250 HP Powerglide car is finally finished and on the road.
It runs great (4360 FI unit) but during a long drive today I noticed the PG (recently rebuilt) slipping in high gear. I stopped for a few minutes, checked the fluid level (it was a little overfilled). Got back on the road, low gear seems fine but after a minute in high gear it would slip some when I gave it gas.
The trans fluid looks clear and not discolored.
Any ideas what the problem could be???
I'm wondering if the shift linkage could cause this problem if not properly adjusted.
Thanks in advance.
Thanks in advance.
BUT it could also be the banana seal or the clutch pack seal as Michael said which would mean removing the PG and open it.
