I checked the archives and could not find info specific to my problem. I have a '71 and decided to do a lamp check as I am do for annual DMV inspection.
My signals are fine. All lights work. The hazzard flasher will cause the front and rear lamps to blink and the front side marker lamps. The rear side lamps will illuminate with the head light switch but not blink with the hazzard flasher.
I am pretty certain that they have only one filament, so if the lamp works in the headlight / parking light mode, it should flash as does the front. Right now I am confused
Anyone had this problem before I have to go crawling down under? Thanks...
Ken
Anyone had this problem before I have to go crawling down under? Thanks...Ken
