1962 air cleaner base - NCRS Discussion Boards
  • Jerry K.
    • December 1, 1981
    • 93
    I have some questions about there being two different bases, the tanged carb base for WCFB and a seperate one without an alignment tang for the AFB. For years I have tried to find a tanged base for my 62 AFB and none will fit. The judges say that my reproduction should have a tang, I say there must be two styles. There is no way a tanged air cleaner base will fit an AFB.
    Jerry
  • Christopher R.
    • March 31, 1975
    • 1599
    Re: 1962 air cleaner base
    Aha! This explains much. I screwed around with this for months before I gave up. I thought I was doing something wrong. Or, that the base I found was screwed up.
    I have noticed that some bases have the tabs, and some do not. And the ones that do not have the tab do not appear to have had them cut out.
    Learn something every day.
    • Jerry K.
      • December 1, 1981
      • 93
      I'm not saying that I'm right, it's just my opinion.
      Jerry
      • Bill O.
        • April 1, 2006
        • 542
        I have an original air cleaner base with the correct base locators that fits my '62 340 with AFB perfectly.
        Suggest you contact Richard Fortier, the former owner of Paragon Reproductions @ 810-750-1472. I know he can do a beautiful job of silk screening an original base if you need that and last time I spoke with him he said he was going to reproduce these bases as original. He may even have an original for sale. I'd definitely give it a try.
        Good luck,
        Bill
