Question on C3 wipers - NCRS Discussion Boards
    Re: Question on C3 wipers
    Go 'shopping' at your friendly local scrap yard. Look for 'narrow' windshield Chevy passenger cars from that era (Camaro, Nova) and you should find a set of 'correct/original' 16" Trico blade holders for your Corvette (perhaps sans the blackout finish)...
      I'm not so certain the blade holders he pictured are 'correct' for the era Tricos... My recollection is the distant end (away from the latch lock) of original holders was crimped into a fold to prevent the refill from 'overhanging' the holder.
      From what I can see in the pictures posted, both ends of the blade holder are open allowing the refill to protrude...
      • William M.
        • July 31, 1993
        • 390
        #18
        Found a source for supposedly correct Trico's. I ordered them and we'll see...
        Bloomington Gold 2011
        Corvette Magazine 9/11
        Bloomington Gold 2013
        Corvette Magazine 3/13
        • William M.
          • July 31, 1993
          • 390
          #19
          Originally posted by Jack Humphrey (17100)
          Those look to be today's Trico service replacement blade holders. Note they're thick at the center pivot attachment and narrow toward the blade holder ends. That tiny bit of difference in blade holder upper surface geometry can pose a fit/function problem with early Shark cars...
          Since the washer tubes are integral to the arms, the tube raises over the blade on one side (RH) to put washer fluid down on the inside edge of the blade's rubber. The extra width at the peak of the blade holder can create an interference fit issue with the RH washer tube causing the assembled blade to sit taller on the glass than the factory original did. Sitting taller can wind up creating a top side interference between the blade and the wiper door during wiper shut down/parking operations.
          That's one of the reasons I like to keep a handful of used factory original 16" Trico blade holders around. They fit and function better than either today's service replacement blades from Trico or 'clone' blades do.
          Fortunately, 73's don't have that pesky wiper door.
          • William M.
            • July 31, 1993
            • 390
            #20
            Problem solved, found NOS Trico holders with Trico inserts, exactly 16":
            • Peter L.
              • May 31, 1983
              • 1930
              #21
              William - The wiper blade assemblies look great. One point on installation. The wiper blade assemblies are usually installed on the arms with the Latch-Lock clip of the refill is at the bottom end. The passenger side wiper blade assembly installation is typical while the driver side wiper blade assembly installation should be flipped 180 degrees so the Latch-Lock clip is at the bottom. Pete
              • William M.
                • July 31, 1993
                • 390
                #22
                Oh. That would make "TRICO" read upside down on the driver's side. Is that right?
                • Peter L.
                  • May 31, 1983
                  • 1930
                  #23
                  William - The happens all the time with wiper blade assemblies that rest towards the middle since both wiper blade assemblies are identical usually down to the logo stamping.
                  My experience is that the judges look for the logo and are not looking for the logo on the wiper holders to read right side up or down. But they should be looking at installation.
                  Your car, your call; but please check around on other cars on the wiper blade assembly installation.
                  Pete
                    #24
                    Ain't it amazing what happens with the right parts?
                    • William M.
                      • July 31, 1993
                      • 390
                      #25
                      Pete
                      Thanks. Anyone else care to chime in about driver's side Trico label up or down?
                        #26
                        I agree with Pete... The latch lock ends were typically installed toward the bottom to increase visibility through the glass during sweeping action.
                        As far as the orientation of the Trico emboss, this is a non-issue in my mind, as Pete said...
                          • 15573
                          #27
                          Many have Trico on both ends, those that don't just don't.
                            #28
                            An EXCELLENT explanation! I've seen that on C2 era blade holders and heard various stories regarding how that indicated a difference between factory original and service replacement parts. But, I LIKE your explanation much better, Terry!!!
                            • William M.
                              • July 31, 1993
                              • 390
                              #29
                              I think I finally got it right. Thanks guys!
                                • 15573
                                #30
                                I thought the Lock-latch goes toward the bottom. That is what Jack said above, and what we looked for at the Regional this weekend. Of course I was the rookie and relied on John Ballard for advice. Exterior judging is not usually my domain.
