I have been working with Jon Banner (Fuel Injection Connection) to get a set of ethanol-resistant fuel injectors that have original appearance and function. Attached are a couple pictures of what I have installed in my 1990 ZR-1. These are 1995 Delphi injectors that have been modified to fit the Z. The part number, of course, is not correct, but everything else is. The car runs perfect.
Some of you may not know it, but the early multi-port injectors were wet-coil injectors, which means that the gasoline is in direct contact with the injector coils. The ethanol in newer fuels deteriorates the insulation on the injectors (mine made it to about 12,000 miles) at which time they begin to short out. Initially, the car actually seems to run a bit better, because the injector tends to stay open a bit longer. It first shows up during emissions testing. As the injectors deteriorate they stay open way too long and short completely out, causing them to quit. At this point the inectors put such a draw on the coil packs that they can short out as well, usually after the car has been run a while. Later, the coil just fails completely.
Putting the old-style Multeck injectors that are going to fail again did not make sense to me, although I can now pull, reassemble, start, pull, reassemble, and start in less than 4 hours, as I had a new GM 545 coil crap the bed on me, which was found after the first reassembly. If anyone is interested in these you can either PM me or just go to the FIC site, fuelinjection connection.com. If you call (numbers on the website) ask for Jon and tell him you want the same injectors sold to Jim White. I hope this helps some of you out, and no, there's no kickbacks. It has just taken me several sets of injectors and much pain to get this far.
Jim
Jim
