68 Vented Gas Cap Test? - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    How does one determine if the gas cap (vented) is not fuctioning properly? What would be the symptoms?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
    Re: 68 Vented Gas Cap Test?
    Jack -
    Generally, if you shake the cap, it should rattle; if it rattles, it's probably OK.
    • Jim T.
      • March 1, 1993
      • 5351
      John I tried your shake the gas cap suggestion to see if my original owner 68's original vented gas cap would rattle.
      John it did not rattle. What is not seen inside my 68's gas cap that would make the rattle?
        Jim -
        A vacuum/pressure valve.
