I've been thru 3 master cylinders in the last week. All three were GM castings. Two rebuilts and a new Delco. The Delco was made in china, no wonder it was junk. All three would bench bleed the front cylinder with good pressure. The rears were dead as in no pressure, no air, no fluid. But still no action/pressure from the piston. The only way I could get fluid to pass was via vacuum using the Mighty Might vacuum pump. This is a 1" bore for a non power brake '72. Only one rebuild had bleeder screws.
Anybody found a good replacement master cylinder? It does not have to be for flight judging just functional.
