I ran my 67 yesterday for the first time since pulling the intake, carburetor throttle shaft bushings, breakerless ignition etc..
Car runs great but I have a carburetor question again. At idle 500/550 RPM, emulsion screws approx 5/8-3/4 turns out on each side the throttle blades are not exposing any of the transfer slot. Turning the idle screw to increase idle I encounter a lean miss with transition from curb idle to transfer circuit. If I open emulsion screws to 1 1/4 turn this gets covered up but idle is dirty.
I can't set blades to expose transfer slot because idle is to fast. I noticed a small pin hole below the transfer slots on primary side that's below the throttle blades I guess to keep prime, (like the secondary pin holes so the gas never gets stale). The secondary blades are closed, no gas dripping perculation etc that I can see at this time. The car ran for approx two hours yesterday this is the only issue.
I can get the car to idle at 500/550 RPM with 19" vacuum, this is not a accellerator pump problem. Any tuning help is appreciated, could I have to much idle timing?? Idle timing is 26*- (10* initial, vacuum advance 16*)
