70 sb TCS nut and Carb nut finish - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Should the finish be black phosphate or bright zinc?
    Thanks!
    Bill
    • 6940
    Re: 70 sb TCS nut and Carb nut finish
    Bill, If You Have A Holley Carb, The Nuts W/ Built In Washers Are Blk. Phos., The Tcs The Same, If You Have A Rochester Carb They Are Bolts Rather Than Studs And They Are Blk. Phos.
    • Bill L.
      • February 1, 2004
      • 1403
      Black bolts for front and black nuts for back. L46 4 speed with Q-jet.
      Thanks!
