Screws for '57 Small Sill Step Plate - NCRS Discussion Boards
  • Charles C.
    • May 31, 1978
    • 65
    I have seen one post on this but am still unsure of the screws used on the 56-60 small sill (at the door threshold) step plate. Are these countersunk, phillips head screws that have a head just a bit larger than the hole. The reason I ask is that the holes in my original sill step plates do not look like the rim has been indented at all which will be the case if countersunk screws are used. Thanks. Charles
  • Charles C.
    • May 31, 1978
    • 65
    • Doug F.
      • November 1, 1983
      • 322
      Re: Screws for '57 Small Sill Step Plate
      #8 pan head stainless is what i use, AUVECO # 13270, or send me a sase and i'll send you 8 of em, cary faber, 2232 n 21 ave, phx az 85009
      • Joel M.
        • May 31, 1975
        • 141
        You might consider #8 shank #6 head chrome plated steel phillips pan head.
        • David S.
          • December 1, 1982
          • 310
          Re: Screws for '57 Sall Sill Step Plate
          Hi charles.
          I am going to try to post a few pictures from my 57 bowtie car that should answer you question.
          Let me know if you need anything more.
          Dave
