Can some one post a picture or tell me which bellhousing bolt does the battery grond wire go under? I have it on the third one down from the top. Also does it have a washer? The rest do not. What is rhe configuration of the washer if any? My copy of the A.I.M. is poor in that area. Thank you Dale
67 C-60 battery ground cable
Re: 67 C-60 battery ground cable
Dale -
There's no lock washer (if there was, the number would be called out on the A.I.M. sheet). Although the A.I.M. sheet isn't a precision drawing, it appears to show the bolt as the bottom one - the top of the oil filter canister is even with the bottom bolt on an actual block, and the illustration shows the bolt below the top of the canister. Have no idea if that's the "correct" interpretation or not.- Top
