I am having a posi rear end built to replace the non-posi unit installed in my 1960.
I bought a correctly numbered and dated posi 3rd member (originally it had 3.70 gears), an Eaton posi unit (from Sadler Powertrain for $449 if anyone is interested vs $600 at Summit), a US Gear 3.70 R & P and new pinion yoke (from Tom's Differential) and the Master rebuild kit (Timken bearings, seals, shims, bolts, crush sleeve, etc).
We set the backlash at .005 and used a .028 R & P shim to get the optimal pattern on the drive side of gears. Run-out is 2.5 thousands measured in 5 different places. The guy helping me has done done over 100 rear ends from various muscle cars and is a diesel truck mechanic by trade.
Here is my question:
Has anyone heard of having to grind some of the lower inside of the 3rd member case to increase the clearance with the attachment flange on the Eaton posi unit ? There is no bevel on the edge which would have prevented this problem. The clearance is just a few thousands from the lower (bottom) side of the case.
Should we grind a bit out to give 20 thousands clearance or so ?
