2000 Power Windows - NCRS Discussion Boards
2000 Power Windows
  • Darold S.
    Infrequent User
    • September 30, 1974
    • 7
    2000 Power Windows
    My 2000 power windows work intermittently - the pass. is better than the driver's. It seems like a loose connection but I do not know wherer to start.
  • Scott S.
    • March 1, 1979
    • 747
    Re: 2000 Power Windows
    Darold, Our 2000 was rewired by the dealer at 50,000 miles. Resoldered both doors inside. Recently the power door locks are intermittent. Bet you 1957 does not have these problems, Progress, you say. Looking forward to seeing you in July at the Nats.
    Scott Sinclair
    • Tom H.
      • December 1, 1993
      • 3440
      Scott Sinclair
      Door lock modules seem to be the guilty culprit most times for me on the C5 power lock issues.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Dave K.
        • November 1, 1999
        • 951
        There is a very good article in the Corvette Forum that addresses power door locks and windows in the C5 Technical Forum. I believe under FAQ.
        Dave K.
        • Clem Z.
          • January 1, 2006
          • 9427
          if the wring is good going thru the door post and the door they say that the commutators in the motors get glazed up and cause this problem. they say you should run your windows up and down every time you drive the car to help prevent this
