Timing Cover 67 435 Block - NCRS Discussion Boards
  • Howard P.
    • May 20, 2008
    • 67
    Does anyone have a known correct picture of a 67 BB 435 Engine Timing Cover. I am needing to confirm holes and are extra dowel holes in these covers.
    Re: Timing Cover 67 435 Block
    If memory serves, '67 was when certain running changes were made to the timing cover (dropped the captive nut for the no longer used oil pan to timing cover bolt + added dowel pin holes). But, my memory may be foggy on this one so others can chime in.
    If I'm right, then you've got an early vs. late issue to wrestle with vs. a single ended "What's correct for '67 BB?" question...
    • Howard P.
      • May 20, 2008
      • 67
      Jack
      Thanks for your reply. My engine is late October 66 casting code.
      Howie
      • William C.
        • May 31, 1975
        • 6037
        Parts book (1971 ed) indicates the change in the gasket (and thus the cover) was between the 68 and 69 model change.
        Bill Clupper #618
          Jack-----
          The dowel pins were not added until later in the 1968 model year. However, the screw attachment for the front oil pan-to-cover did cease after the 1966 model year.
          Attached is a photo of what I believe is a 1965-66 timing cover. This cover should be the same as the 67 except that the 67 MIGHT delete the captive nut. I'm not sure that some 67's had the captive nut (unused), though.
          • Howard P.
            • May 20, 2008
            • 67
            Joe
            Thanks very much for the photo this will assist me greatly
            Howie
            • Joe R.
              • May 31, 2006
              • 1822
              Howie,
              The following thread has some info on a change to the timing cover for 67 related to the removal of the center captive nut at the bottom.
              https://www.forums.ncrs.org/showthre...64468&uid=6149
              Joe
              • Bill W.
                • March 1, 1980
                • 2000
                timing tab is to long for a 65 it should be a 66
                • Howard P.
                  • May 20, 2008
                  • 67
                  Thanks all for their input it has been very helpfull
                  Howie
