63 Powerglide Shifter - Drive to Low Detent - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    The other day driving the '63 at about 50 mph, I put my hand on the shifter, thinking I was driving my 4-speed '59, and it dropped down to low gear. It scared the heck out of me.
    It seems you shouldn't be able to go from D to L without moving the handle to the side first, as appears on the shift pattern plate. Is there a problem with this one?
    Rich
  • Arnold P.
    • August 31, 2005
    • 48
    Re: 63 Powerglide Shifter - Drive to Low Detent
    hi.rich. i have the same situation with my 63. this is normal. there isn't any detent or lock-out.pappy
    • Jim L.
      • September 30, 1979
      • 1805
      The detent might be worn, but there is definitely one built into the linkage design.
      Jim
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Hmmmm, so I was playing around in the garage with the shifter some more. It seems like it's intermittent. With engine off, if I go from park to drive quickly, it seems to not drop to Low but stops. If I wiggle a little bit, it'll drop to Low.
        Pappy, maybe both of them are worn... yours and mine(i mean hers....wife's car). I'll get under it and see if I see anything odd.
        Rich
