Re: L84 fuel percolation
Hi Dan,
For certain it is supposed to close completely on the early spiders, which have gravity operated check valves. On Sting Ray spiders with the spring operated valves, the valve should still be forced closed; however that all depends on the strength of the spring.
During a hot restart of a 7380 unit, you'd be holding the throttle open and the cam on the bellcrank would trip the microswitch. That, in turn, would prevent the starting fuel bypass valve from opening. So, the scenario of the engine mounted pump momentarily pressurizing the spider to stop the percolation woudn't happen.
On a hot restart, the engine is actually slightly flooded anyway from residual fuel in the nozzle lines. That's the reason for going to WOT to restart.
When a solution to the percolation problem is finally developed, no matter what it is, I have a hunch the result will be, um, a less attractive FI unit.
Jim
Hi Dan,
Only 'loose' fuel would be the tiny amount in the spider itself to 'cook off'? When the 380 unit starts, it gets a shot of fuel from the main fuel pump which then refills the spider with slightly pressurized fuel to help get rid of the boiling residual fuel in the spiders.
Seems like an insulating wrap to shield the spider lines would be a step in the right direction, just look ugly
Jim
