I bought an original 091 coil and had a shop to install it. The shop said the coil was bad and it melted the wires going from the ballast resistor to the starter. I tested the coil for resistance with a volt meter last night and was getting around 2 ohms on the primary, about 8K ohms from the center to either + or -, and an open circuit from any either post or the center to the can. That appears to be within the specs for the coil according to a motors manual. They indicated that the engine was running when smoke started coming from the engine compartment.
Now I'm wondering if they left the ignition on with the points closed which burned the wires rather than the coil being bad. Is it possible that as the engine heated the coil it shorted out? If so, wouldn't the engine have died due to the short?
_________________
Update: the resistance between the + and - terminals is 1.3 ohms and the resitance between the + or - and the coil wire terminal is 8.66 K ohms. Again open circuit from any terminal to can.
_________________
