65 Power Brake Booster - NCRS Discussion Boards
  • Martin T.
    • May 31, 2006
    • 196
    Did the 65 power brake booster have any identifing markings that differentiated it from other years? I was told it had a Julian Date marked on one of the tabs and later told that 65s did not (true or not?). Anything else to look for?
  • James G.
    • May 31, 1976
    • 1556
    Re: 65 Power Brake Booster
    Call Dennis Hakim at (805) 654-0662 in Ventura, California. Dennis has been a 65 NCRS MasterJudge for many years. He also has been on the 1965 judging team at BLOOMINGTON for over 15 years. If he does not know the answer, he will know who will.
    • Martin T.
      • May 31, 2006
      • 196
      Thanks Jim. I left Dennis a message.
        I think this is nicely covered in the descriptive text contained in the 1965 NCRS Judging Guide. Why not crack open your copy and see what's said?
        • Martin T.
          • May 31, 2006
          • 196
          Jack, Unfortunately, I loaned my judging guide out and do not have it to look at. However, I did hear that a Julian Date is correct.
          • Clark K.
            • January 12, 2009
            • 536
            I have attached a photo of my 1965 with the power brake booster.
            -Clark
            • Clark K.
              • January 12, 2009
              • 536
              I got out my '65 JG. It states: "The booster part number is 5467011. the last four digits, "7011" are stamped into the tabs at the perimeter (10:00 o'clock & 4:00 o'clock) where both halves joint together." The '65 JG mentions no other numbers, Julian, or otherwise.
              If, perhaps, you meant the master cylinder, here is what numbers are addressed for this part: "The casting number 5467084, "DELCO MORAINE" with logo, and "1" DIA" are visible on the inboard side."
              The '65 JG also addresses non-power brake cars and the differences for the fuelie with power brakes, all on pages 131-132 under the chassis section.
              -Clark
              • Martin T.
                • May 31, 2006
                • 196
                Clark, Thanks for the information on the booster (I was not looking for info on the cylinder). Would it be possible the judging manual left this information out for any reason?
                • Clark K.
                  • January 12, 2009
                  • 536
                  I can only speculate about why the '65 JG does not go into more detail about the power brake booster.
                  I do know that knowledge of these fine cars is evolving with new information coming forward every so often. The JG's are written by one or more knowledgeable enthusiasts. I do believe that the authors make a good faith effort to spell out everything. I also know that when errors are noticed, they are corrected as soon as possible. They do it for the love of the car. -Clark
                  • Bill M.
                    • April 1, 1977
                    • 1386
                    -Clark
                    My '65 booster has 7011 on one tab and 228 on the other tab.
                    • Martin T.
                      • May 31, 2006
                      • 196
                      Well, there you have it. My confusion renewed.
                      • Page C.
                        • February 1, 1979
                        • 802
                        My 1965 booster has 7011 on one tab and 297 on the other. It's a late Nov-early Dec 1964 built car.
                        Regards
                        Page Campbell
                        • Martin T.
                          • May 31, 2006
                          • 196
                          Thanks Page. Also, thank you again on the information and photos on the engine. It's going through the rebuilding process now. Martin
                          • Jim D.
                            Infrequent User
                            • December 1, 2003
                            • 12
                            Hello... So I'm understanding this correctly, My PB 65 coupe has a cylinder with the casting # 5467084... is this an orginal casting or repop?
                            Also... theres a 'D3' on the cylinder... what exactly is this? a date code?
                            located between the 'F' & 'R'.
                            thank you... jim
                            • James G.
                              • May 31, 1976
                              • 1556
                              Regards
                              Page Campbell
                              7011 is thepart number and 297 is the 297th day of the year. So Saturday, October 24, 1965 is the build date of the booster.
                              Interesting they were working Saturday, 10-24 when the rest of the St. Louis plant was on strike from 9-30 until 11-3.
                              My guess Page is your car was built around November 15 with a vin around 2730 ?
