noisy clutch petal - NCRS Discussion Boards
noisy clutch petal
  • Harry L.
    • December 22, 2008
    • 370
    noisy clutch petal
    how do I tightin my clutch to keep it from vibrating? IF I just touch the petal with my foot it stops the noise. Thank for any solutions to my problem.
    Re: noisy clutch petal
    Harry---
    Check to be sure that all the springs in the system are in place and in good condition. If that turns out to solve the problem, you'll be lucky since those are easy to remedy.
    Another problem source is worn bushings supporting the pedal pivot shaft. That's a lot harder to remedy.
      • 6940
      Harry, Sometimes Its Not The Linkage, The Pressure Plate Fingers Sometimes A Few Loose The Tension And Causes The The Throw Out Bearing To Jump Around And Sends It Back Up The Pedal Through The Linkage. Just Check For Any Or Slight Movement At The Clutch Fork Area When The Cars Running.
      • Bill I.
        • January 29, 2008
        • 554
        Harry, when you say just touch the petal, are you still in that 'free zone', before you feel any resistance? Bill
        • Vince C.
          • June 14, 2009
          • 1
          I had the same noise. The small rubber clutch pedal bumper at the top of the clutch pedal had worn through and let metal touch metal when the clutch was out. A $1.50 fix.
          • Harry L.
            • December 22, 2008
            • 370
            I was missing one of my anti rattle springs. Sometimes it is the smallest thing. DUTCH
