Re: 63 spark plug wire terminal ends
Well, I dunno JD. The info on page 164 of the Adams book that refers to the FI spark plug wires in the AIM is only for the unique routing of those wires. That sheet/info was added later in the 63 model run because the routing was slightly different than that used for the straight wire set for all other engines.
The info on the upper left on page 166 does indeed show the unique wire set but there's no date on the sheet and no info that shows it was introduced later in the 63 model year.
The photo of a "late" production car that you refer to on page 140 is actually NOT a late production car. Notice the unplated fuel lines, fuel filter bracket and black painted oil filler tube/cap etc etc? This is actually a very early car and it has 90* spark plug wires.
The car on page 136 that you refer to as a "prototype/early pilot line car is actually a mid 63 production car being fitted with a 64-65 FI unit for testing. Did you notice that the FI unit has no cranking signal valve but does have a starting by-pass switch on the throttle lever? A 64-65 style oil filler tube and no vent tube from the air cleaner to oil filler tube.
We know this is a mid production car because of the hood blocks/wedges and unpainted hood lock plates. Typical of engineering to use a mid production car to test and evaluate components for the next years model.
And finally, WHY in the world would engineering hold up the 90* spark plug wires when they were on paper and in actual physical reality well before start of production in September of 1962?
Nothing in the Noland Adams book has shown me that straight wires were used on early 63 FI cars.
