Bleeding '66 Brake Question... - NCRS Discussion Boards
  • Larry S.
    • September 19, 2007
    • 204
    I have installed 2 remanufactured front brake calipers (old ones leaking) and must now bleed the lines. I understand that I start at the farthest wheel from the master cylinder (rear right wheel). The rear calipers have two bleeder screws on each caliper. Do I bleed the outer bleeder first, then the inner bleeder after?
    Re: Bleeding '66 Brake Question...
    Larry -
    I do the inner rear bleeder first - works for me.
    • Larry S.
      • 204
      Thanks John. I'll do it tomorrow.
        • 15610
        If you only worked on the front calipers, I would bleed them first and then do the rears - essentially completely flush the system with a quart of fluid so it is all fresh and moisture/contaminant free. With two bleed valves, first bleed the valve closest to the input line. There is really no "magic" way to bleed a brake system. Start with the corner/valve that is the shortest escape path for any suspected entrapped air.
        If you change the master cylinder, the shortest route to purge air from the M/C to junction block line on a single MC system is out the left front.
        A little intuition is all it takes - what's the shortest escape path for suspected entrapped air.
        • Larry S.
          • 204
          Thanks Duke . I DID IT THIS MORNING AND ALL IS WELL.
