Automatic transmission - NCRS Discussion Boards
  • William G.
    • April 1, 1978
    • 154
    what is difference between a 4sp and automatic transmission
    mounting cushion on a 1965 300hp with automatic.
    i have a cushion but dont know if it is for a 4sp or automatic
  • Joe R.
    • March 1, 2002
    • 1356
    Re: Automatic transmission
    I was under the impression that the mounting cushion was the same for either the Powerglide or the manual transmission, but I could be wrong.
      The 2133 transmission mount was used on all three '64-'67 transmissions; the part number is usually molded into the rubber portion of the mount.
      • William G.
        • April 1, 1978
        • 154
        joe and john
        why do the corvette reproduction parts catalog list different parts #
        for 64-77 with powerglide for the tranmission mounting cushion.
        that is why i am confused
        thanks for you reply.
        bill
          Originally posted by William Garrett (1868)
          joe and john
          bill
          I have no idea. The GM P&A book shows the same mount for all three transmissions, and so does the 1965 Assembly Manual; LICS has it right, Paragon does not.
          • William G.
            • April 1, 1978
            • 154
            John
            you are right paragon list it being different
            thanks for the reply and straightening me out on this one
            thanks again
            bill
